Thread: Almost there...
Old 06-02-2021, 03:18 PM   #2
elav
Do you mean the microswitch for the latch? If so that is used for dropping the windows down/up when the top is opened or closed. May be used for other things, but it is absolutely used for that. I dont think it has anything to do an occupancy sensor (if one even exists)
Dont know what year yours is (put in signature it helps us help you).
Yes, the micro switch for the convertible latch. The latch works perfectly dropping the windows. I read in the Bentley manual that if the convertible top is down and you lock the car, it turns off the occupancy sensor - I'm not sure if my car has one but trying to figure out what else to check.
New to Durametric - there isn't any place where you can see the current states of the various latches, right? I simply want to see which latch the car thinks isn't closed.
BTW, thanks for pointing out I should add a signature - done!
'98 Boxster 986
'87 911 Carrera Cabriolet
elav is online now   Reply With Quote
