Old 05-29-2021, 12:32 PM   #5
97gtaboxter
yea, but the question is why are you wanting to replace your headlights?
My point is, there is nothing to be gained with litronics headlights in a non car. If your existing are broken and you can get them cheaper then non then sure, just dont expect them to work as good cause they will default to the down position, which means you wont get much lighting down the road.
I need to replace my lights because the reflectors are cracked and yellowing. A common issue.
Your point is well taken though and this is why I am on this forum. From my research I have 4 options.
1) replace original headlights with replacement standard OEM like my existing ones.
2) replace original headlight with xenon litronics headlights (used)
3) replace original headlights with aftermarket HID. I am not sure I want to do this as I am unsure of the quality of these lights. I have read that other guys have done it. They look good but still unsure
4) open up my original headlights and fit with with xenon projector. Yes, I have seen the videos. However, this is not something I really want to tackle. I am not sure I like the idea of opening up headlight assemblies.
Thoughts?
97gtaboxter is offline   Reply With Quote
