Old 04-23-2021, 01:40 PM   #1
RRobbins
2003 Boxster Passenger Side Window Issue
Hello! I'm a new Porsche owner and new to the forum. I have the common issue of the window on the passenger side not automatically coming down slightly to clear the top. The micro switches on the inside and outside handles seem to be working as it does move, just not enough, so I assume its cable adjustment. My question is what type of sealant should you use to seal up the foam membrane when you put everything back together?
RRobbins is offline   Reply With Quote
