Old 04-15-2021, 08:57 PM   #12
dghii
Keep in mind most non-OE tops reduce engine access from above!
True but...
Any Boxster has limited access to the top of the engine, by design.
How often do you have to access the top of your engine and for how long?
The glass window top , even on a 3 bow frame, has more than enough access for routine maintenance (air filter , PS fluid etc.).
If I'd had a job that required extended access to the top of the motor, I'd spend a half hour and remove the entire top and frame. I never had a reason to do such but honestly, it wouldn't (and didn't) deter me from the benefit of having a new top with a nice clear rear window.
