Old 03-29-2021, 09:39 AM   #19
Quadcammer
Originally Posted by 10/10ths View Post
....As I posted, twice already, it’s not that the oil itself “goes bad”, it’s that the oil sump fills with water from condensation and the fuel that gets by the piston rings.
The contaminants collect in the sump.
Just sitting in there, corrosion occurs and your oil will not be as good a lubricant because it won’t just be oil that is being pumped throughout your engine on startup.
And for crying out loud, if you invested in a sports car, you made a commitment to owning a complex piece of machinery, and that requires maintenance. And that costs money.
So suck it up, and drop a $100 on an oil change.
I’m sorry, but if $100 every six months is “wasting money”, then you should not have invested in the car in the first place.
Ride a bicycle.
And lube the bike chain.
you realize I hope, that the oil and fuel in the oil boil off when you drive it right? If you did a used oil analysis, you'd realize that the amount of water and fuel in a car with no mechanical issues is very minimal.
