Old 03-25-2021, 06:37 PM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
Question:
The coolant line running into/out of the control valve (928-574-573-03-M53) for the transmission cooler. Where does that hose fit in with the coolant tank? Thank you.
The Tiptronic cooling lines both connect to metal tubes that are clamped to the lower right side of the engine. The upper one of those connects to a "T" hose at the front of the engine. The lower hose connects to the 4-way hose at the front of the engine. There is no direct line to the coolant tank.
Buy $GME. (This is not investment advice, I just like the stock.)
