Old 03-18-2021, 05:13 PM   #1
9864ever
9864ever's Avatar
Mine is an S too so I have to cut as well. From what I see it's easier to cut it out from the back is that what you did? There's a clear line where it looks like it should separate from what I see.
Originally Posted by rfuerst911sc View Post
Mine does not have a hump or bump in the middle , it may have been tweeked during shipment . Also because my Boxster is an S model with the third radiator I cut out that center section for air flow . I used a hole saw about the same size as the opening and drilled the two ends . Then cut out the piece in-between with a air zip wheel . A little filing and sanding and good to go .
9864ever is offline   Reply With Quote
