Old 03-06-2021, 03:38 AM   #12
CrisZenithBlue
CrisZenithBlue's Avatar
tip for when you install the Fister: you will most likely need to cut an inch and a bit off the "C" pipes that go into each side of the muffler (the ones between the second cats and muffler). This is because Fister welds a piece of metal "mesh" inside each side pipe of the muffler and that wont allow the C pipe to sit deep enough. I had a hard time getting it to seat well until i cut a bit and then it fit like a glove. It will make sense once you have it and try to mock up.
CrisZenithBlue is offline   Reply With Quote
