Old 02-01-2021, 06:57 AM   #27
blue62
Originally Posted by kbod View Post
I specifically remember when I took apart the camshaft tensioner, I used white nail polish on the dimple on the gear and its corresponding chain link. when i put it back together It all lined up with my paint marks. I did notice that my ims locking took does have a bit of play even when it is "locked" which is why I want to just adjust my camshaft a tad, I just don't know if i should nudge it clock wise or counter clock wise, do my deviations say what direction it is off in?
deviations are usually stated in positive or negative form.
So I would think advanced would be positive and retarded negative.
I just did a little reading on how the cam timing is set up on these engines.
I see where your going with the attempt to "adjust the cams, makes sense.
If your cams have the four bolt setup on the sprocket, timing could have "slipped there at some point.
You just have to figure out which direction to go.
Keep us posted on the results.
