Old 10-15-2020, 10:08 AM   #1
JFP in PA
Originally Posted by beater986 View Post
Are these carriers compatible with the base axles or would it require special axles?
Also, dimensionally-speaking, do we know the reason why the s calipers don't fit the base carriers?
Is this something I can whip up a bracket for?
It is because the S uses an entirely different e brake assembly, which will not fit on the base carriers. In order to make it work, you would need to fabricate an entirely new rotor with a different inside diameter for the base e brake. No such rotor currently exists, and would cost a fortune to make.
