Old 09-07-2020, 08:19 PM   #3
rflores2323
I'm not familiar With the icarscan, will it read things like cam deviation? MAF? O2 sensor voltages? Fuel trims? Etc? How about initializing accessories? (Fans, a/c clutch, etc)
Yes it will read live data streams. Not sure about initializing accessories. Have not tried that. I actually haven't used it on my 00 Boxster yet (knock on wood). I used it on my 08 cayenne GTS when I changed the ATF as I had to know the correct ATF fluid temp and the icarscan device worked properly. Also did my plugs,coils,TF case, and oil. Cleared my codes and reset my throttle and maintenance aswell.
Worked great.
Sent from my HD1907 using Tapatalk
rflores2323 is offline   Reply With Quote
