Old 08-29-2020, 04:23 PM   #15
dghii
Originally Posted by RA1 View Post
Just did this, noise almost stops completely when slightly turning to the left. Gets worse when turning to the right. Does this mean rear driver side wheel bearing is bad?
Do both. At this mileage, you're going to do both eventually anyway. This is a driveway job if you're handy. Wheel bearings are under $50 each. Pull your wheel hub and press out the bearing. If you don't have a press, go to a garage or auto parts store and have them press out the old and in the new. Not bad.
