Old 08-12-2020, 08:55 PM   #20
maytag
Who's askin'?
maytag's Avatar
Originally Posted by timqqt View Post
Thanks. I am gonna work on those. I just replaced the engine air filter. Some oil residual on it. Another sign of failed AOS?
Tim, you're getting good help here from Jager, so I hesitate to interrupt.
However:
I have seen oil (in small amounts) get to the air filter due to a bad aos, when combined with a poorly running engine.
Under normal conditions air only moves in one direction through the intake tube. However: if your engine "backfires", even just a slight stutter or a cough, then yes, you can see air moving the other direction, though only momentarily. I wouldn't worry about it at all, for the moment, as you could end up chasing squirrels that aren't there. I would focus first on your AOS, then on your vacuum leaks.
Then let us know how it goes.
