Old 08-05-2020, 05:44 AM   #28
Qingdao
Qingdao's Avatar
Originally Posted by Seal1968 View Post
If you want an inexpensive and quick repair, and it's just the clear coming off you can sand the top layers with 400 wet, then re-clear. No need to break through the basecoat into the primer layer and have to re-spray the entire panel. When sanding the clear it will be a white residue...if you see colour on the sandpaper, you're into the basecoat.
To re-clear you can get 2K clear coat in a rattle can - it has the activator in it, and the UV protection needed. Cans of the 2K clear are @ $35 each.
There's a ton of DIY clearcoat repair videos on YT if you want to tackle this project.
If you feel this above your skill level, a body shop can blow in your hood and top lid easy. They will be able to match the paint codes. Even a Maaco shop could do this for you.
Its a metallic flake paint. Any sanding in the base coat will stand out like a sore thumb.
If you did do this you'd need to put on a control coat of base then re-clear, but at that point its better to just do the normal two base coats and one control coat.
'98 PP13B powered "RX986"
