Old 07-27-2020, 01:01 PM   #10
maytag
Who's askin'?
maytag's Avatar
I get it that it's soft metal, but when I think crush washers I think rolled metal ones that are hollow inside and flatten as you tighten them.
I guess aluminum is more like the cheap version of brass washers.
I can't remember the last time I saw a crush washer of the type you're describing. I HAVE seen them, so I know what you're talking about, but all I've ever seen used over the last 30 years (including factory parts for Porsche & Ferrari) is the Flat Washer of (usually) aluminum, but occasionally copper. (Never brass. Alu and Cu are MUCH more malleable than brass).
Here's the Porsche Brand washer for the referenced application, you'll note it is a flat, alu washer.
https://www.pelicanparts.com/More_Info/90012310630OEM.htm?pn=900-123-106-30-OEM&bt=Y&fs=0&SVSVSI=1052
Where do YOU buy a crush-washer of the type you're describing?
