Old 06-24-2020, 01:11 AM   #26
DaveBBOXSTER
You may wanna reread my comment #11. The actuator is operated by oil pressure, not by the solenoid, the solenoid operates a valve only that channels oil flow to the piston that advances the timing of the intake camshaft. If the solenoid is faulty, probably the ECU will see that and may trigger the check engine light. I`m just guessing here. If the actuator is not working because it can`t hold the pressure, then you won`t have cam advancement, but your engine is not in danger, not like when timing gets messed up. Just it won`t perform as it should at a certain rpm range. The seals are there to hold the pressure, not for stopping engine oil getting into the actuator. I agree, pulling the sump is probably a good idea to clean the rest of the debris off the oil pickup strainer.
Yes, Thanks - I did read the point about the actuators working on oil pressure not sure if the unit is sealed or taking engine oil to operated I guess it is? I took the car out yesterday for a 20 mile test run and it ran impressively; quick revs response and power and just seemed about right (according to my previous experience of how it drives) I was cautious at first as I don't want to ruin my engine but overall it was good. I saw an ad for the full kit of new timing chains, cylinders and tensioners online for $3,500 that is a very expensive set of parts to replace!
DaveBBOXSTER is offline   Reply With Quote
