Old 06-11-2020, 09:03 PM   #23
maytag
Who's askin'?
maytag's Avatar
Originally Posted by jaykay View Post
I did measure it with a stopwatch way back.....3 to 5000 was significantly better. This was with a big 997 diverter tee. 5K onwards was not an issue. Unfortunately I did not record before and after times. I also reduced the diameter of the air duct from the MAF housing to the TB......I would surmise that this had to do with getting closer to optimum intake charge velocity and acoustics
The snorkel also has what everyone calls a drip tray. I call it an air deflector and think it is designed to direct air into the snork and air box.
It was enough different that you could measure it with a STOPWATCH!?
Jaykay, with respect man, I'm not sure how a guy would do that with any measure of repeatability / accuracy.
I'll give ya the credit though, because what you've done with that stopwatch is more than what I'VE done to try to measure throttle response.... which is nothing. ;-)
Your idea of reducing the size of the intake "pipe" is also counter to conventional wisdom. Again: i haven't tried it, but I'm sure having a hard time imagining improvement from this. Velocity is great, but not if you can't get the volume. That's the whole POINT behind the larger tb.
