Old 04-02-2020, 10:27 AM   #1
piper6909
piper6909's Avatar
I think you have worn thru the lead layer of some rod bearings & starting on the copper layer, that's the last layer of defense for the connecting rods. Once the rod is worn oversize it will start knocking & they are not rebuildible but they will ruin the crankshaft.
Thank you, I think you may be right. I had a hunch it was the copper alloy from the bearings. But I wasn't sure if these bearings were made of a copper alloy or not. When I can get a replacement motor for less than $4k, it's probably not worth doing anything about it now, right?
Like I said earlier, I'm probably going to drive it for another one or two k miles and check it again.
