Old 03-14-2020, 06:53 AM   #1
maytag
Who's askin'?
maytag's Avatar
While I agree that it's most likely the infamous "foam bits" issue, the A/C does also play a critical role in defogging, as it pulls moisture from the air. If you may have noticed, every time you put a car in defrost mode, it always turns on the A/C compressor (unless it's a classic car that never had A/C).
Also, it doesn't really take much airflow to defog the side windows, but having dry air critical. So checking the function of the A/C system does apply here, as well as checking the foam baffles.
I'll stand corrected.
As soon as I confirm it's true. HAHAHAHA.
in Utah, "pulling moisture from the air" isn't a thing. ;-)
But I'll believe you.
