Old 02-21-2020, 09:32 AM   #1
JFP in PA
Originally Posted by kbcvg View Post
Thank you....that being said, would YOU buy a car with smaller bearing and go the replacement/LN route, or a newer, larger bearing car, and just hope for the best?
Six of one, half dozen of the other. I prefer to install the IMS Solution retrofit (currently have two in my personal stable), but if left with no choice but the oversized bearing, I would pull the trans, clutch, and flywheel and remove the bearing's rear seal so it can mist lubricate from the engine sump.
