Old 01-09-2020, 10:57 AM   #11
maytag
Who's askin'?
maytag's Avatar
thanks. honestly, they frighten me from what i've read about them. starting to get shimmies and rattles from the front and back, so thinking rebuild time. current thoughts are:
front - erp lcas (cheaper than everything but the spc units and never heard anything bad about erp). already have stomski racing tie rods. tarret thrust arms. this will get all the rubber out of the system, and the adjustable thrust arms will allow me to widen my track and get rid of front spacers. will have to figure out what i want for front caster setting.
rear - eps thrust arms and lcas (their thrust arms have the harder bushing, and the lcas have a serviceable ball joint). already have rennline toe rods. get aftermarket inner bushings and thrust arm bushings for the new lcas to get the remaining rubber out of the system. camber and track width not an issue at the back.
powerflex sway bar bushings front and back?
TRK:
did you ever settle on a caster setting that you like?
