Thread: Radio confusion
Old 12-21-2019, 07:45 AM   #21
stupidget
Originally Posted by Spizzy View Post
I have an 03 with CDR23, amp in frunk, door and dash speakers. I’ve spent hours searching to try and determine what it is. There’s no Bose stickers, and have no idea if it’s a MOST system, which I believe is a fiber optic type? Are all 03s of this system?
This all started with looking to install a double din, but crutchfield tells me it won’t work with this amp, and I’d have to run new speaker wires, or tap into them at the amp. I don’t want to cut the amp harness so trying to find a work around.
Can someone please educate me?
I have the same setup in my 2004 S. I was going to get a Double DIN system installed and had a guy look at my car to quote how much it'd cost to fit one. He said that what you can do is by-pass the existing amp and simply plug the current speakers into the new head-unit. The amp in the Boxster only outputs about 45W and most new head units will out about 35-40W anyway and they'll be modern tech rather than using an amp which is 16 years old.
The guy quoted me £850 to fit the new double DIN and move the ac unit down to where the 6CD storage tray is.
I'm thinking of fitting a Pioneed SPH-10BT single DIN unit but need to know if I'd need to use any cable adapters.
Did you get any advice from anybody on what to do?
stupidget is offline   Reply With Quote
