Old 10-10-2019, 03:12 AM   #12
piper6909
piper6909's Avatar
Then explain the patented plug in the IMS shaft used by the IMS Solution, specifically to keep oil from flooding the shaft..............
Maybe because with the IMS Solution the oil has nowhere to go on the other end, and thus unable to circulate.
The IMS Solution pumps oil into the bearing from the outside. You don't want that oil going through the bearing into the IMS tube with nowhere else to go because it'll remain there and get stale. That's why they have to use a plug.
The EPS Solution is to feed oil from one end of the tube, out the other end, into the bearing and back into the pan. This allows for circulation.
piper6909 is online now   Reply With Quote
