Old 10-02-2019, 04:45 PM   #5
dghii
One other unsolicited suggestion....Use your Motive dry, just to apply a little pressure (10-15 psi) to the brake MC. You will not run your reservoir dry if you check it after you do each corner. The pluses to this method is not cleanup and no worries about spraying brake fluid (bad hose or cap).
dghii is online now   Reply With Quote
