Old 10-09-2006, 08:29 AM   #2
MNBoxster
Hi,
There's a chronic issue with the fuel filler tubes on some Boxsters. It requires removing the pump/filter (on an '02), level sender and tying the two filler tubes to the rod w/ nylon ties so that it is held out of the way. Pretty easy procedure, but you need to remove the battery and tray to access it. Hope this helps...
Happy Motoring!... Jim'99
