Thread: 2 piece rims
Old 09-06-2019, 12:19 PM   #6
BYprodriver
BYprodriver's Avatar
Originally Posted by SMK Shoe View Post
Kinda new at owning a 986 with two piece rims. Question is does the rim have to come apart to have new tires installed. From what I can tell, the two piece is a inner piece that mounts to the entire outer rim. Not like a Hummer where the two halves ( sorta) mount together. Just trying to figure out if my usual shop can do the work or do I need to find a indy Porsche shop.
No you just need a good tire mounter with decent equipment. Those are optional wheels made for Porsche by BBS. Just make sure you have no air leaks now. That stainless steel band around the rim can be removed & replaced or repaired if it gets dented.
I assume the Hummer has split rims which is 2 halves joined together like a 18 wheeler truck.
