Old 09-06-2019, 06:58 AM   #16
78F350
Motorist & Coffee Drinker
78F350's Avatar
... In case of an accident your seat will fly with you through the front window. I know it's a budget build, but don't do safety relevant things like seat brackets on a no budget attempt.
Regards, Markus
Thanks for the comment and I appreciate your opinion. What I used looks like junk loosely cobbled together, but when it's firmly bolted together, it is stronger and more rigid than many of the commercial products available.
The thickness and strength of the steel angle iron is comparable to the original seat frame and I have it doubled together in the vertical axis. The shoulder harness straps are secured to the roll bar. The lap belt is secured the same as the stock seat belt - left side bolted to the frame, below and aft of the door and only the right side bolted to the seat rail. I considered moving the right side belt mount to the frame, but decided that it would be best to stay with the original mounting as designed by Porsche (using a bolt and spacer from an Audi seat belt). If the seat and I fly through the front window, we will take the roll bar, door frame, and seat rail with us.
