Thread: Fender Removal
Old 09-02-2019, 07:14 AM   #1
9864ever
9864ever's Avatar
Fender Removal
Hi all, I need to remove a damaged front fender on the passenger side. I've removed all but two bolts that are located near the door.
When opening the door, there is a cover on the inside that looks like if i remove it I can access the remaining fender bolts.
There's also a large black plastic reservoir looking thing in the wheelwell. If I remove that I should also get access.
Does anyone have experience removing fenders from the 986?
Would like to know how you tackled those last two bolt that are not able to be seen.
The photo indicates where the bolts are located as I'm pointing to them (that's the new fender that i'll be installing)
9864ever is offline   Reply With Quote
