Old 08-30-2019, 11:21 AM   #1
maytag
Who's askin'?
maytag's Avatar
Four functions of the coolant warning light:
1. Engine coolant level too low; light flashes slowly (0.5 Hz)
2. Engine compartment temperature too high; light flashes slowly (0.5 Hz) (engine compartment blower might be faulty)
3. Engine coolant temperature too high; light is lit; pointer on the right
4. Temperature sensor at water outlet faulty; light flashes rapidly (1 Hz); pointer on the right
Note
The temperature warning in point three is indicated if the conditions "engine coolant temperature too high" and "engine coolant level too low" are present simultaneously
(1Hz = 1 flash per second. 0.5Hz = 2 seconds per flash)
So it might be the temperature sensor is faulty (if the light is rapid flashing).
As always: very helpful. If I were still chasing a squirrel around that engine bay, this would've made all the difference in diagnosing. I'll stash this in my "reference library". Thanks JFP!
