Old 08-17-2019, 05:03 PM   #6
thstone
Originally Posted by Rob175 View Post
I'm hoping to be able to just pull out the cluster far enough to change the bulbs without dealing with the 3 connectors. They say a 6mm socket can be used to easily twist to unlock the bulbs. I have also seen a video on how the connectors "unlock" should I need to gain more access. It appears that the emergeny fasher is the only tough one to unhook, but not impossible.
This is one of the easiest DIY's in the world. When you get in there, everything is pretty obvious. It should only take about 15 mins.
