Old 08-12-2019, 05:53 PM   #1
dghii
When (if) you pull a headlight switch apart, you'll be surprised how small the contacts are and how little pressure is applied. I pulled mine apart and cleaned contacts with erasure and a little sand paper. I tweaked the contacts as best I could for more positive contact and reinstalled. Everything worked fine but after seeing the inside, I bought a spare just in case!
