Old 07-16-2019, 07:03 AM   #2
blue62
Originally Posted by 86fromCA View Post
I have the same issue,..only the other bank. I get code P0300, P0301-03 and a P01340
which is solenoid related. I also get a rattle at 2500RPM or so. Do you get that too?
I think i have the same issue as your having. Have you found your answer yet?
What year is your car? The reason I ask is depending on which DME it has I find that p1340 is either a short to B+ or a short to ground.
Either way I think the p1340 code is telling you that you have a short to battery positive or a short to ground in the wiring to that cam position sensor. or the sensor is shot.
How many miles on the car?
