Old 07-03-2019, 01:59 PM   #4
78F350
Motorist & Coffee Drinker
78F350's Avatar
Question More '97 differences
Putting a 1997 engine in an '01 and I ran across a difference I didn't expect. In the 2001, there's a hose that goes from the coolant tank to the oil cooler. In the 1997 that hose goes to a hard-line that the front of the engine under the AC compressor. That hard-line does not exist on the '01.
I plan to put an "S" oil cooler on the car. What is the best practice?
I'm thinking of:
  • Swapping the cover from the '01 onto the '97 engine where the hard line connects. (Eliminate the hard-line since it has some internal corrosion)
  • Redirecting the hose that connected to the hard-line to the top of the new "S" cooler.
  • I still need to get a look and see what the status is of the adapter plate on this engine...
  • Replacement O rings ...these: 2 (35 X 4 mm), 2 (26 X 3 mm)
    For install will the "S" cooler fit under the intake easily? Anything need to be moved or loosened?
Pics:
Hard-line connection under '97 AC
Blank cover on '01
2001 Oil Cooler (Likely full of debris from #2 rod failure)
Cooler currently on '97
