Old 06-21-2019, 07:41 PM   #2
Laminar Flow
Guest
Posts: n/a
on the second, some aftermarket LCA recommend not tightening that one until the suspension is loaded with the weight of the car. The Porsche guides, Bentley etc don't say that (and I didn't the last time) (but for sure do on the inner bushing)
Okay, so I don't need to mark anything on the lower control arm bolt where it attaches to the frame to return it to the same spot. But how do I get to that bolt to tighten it while it's loaded with the weight of the car? I don't have a lift. Would having the wheels on the ground and the tires turned provide enough room? Or, use ramps maybe?
Edit: I'm assuming the inner bushing is the one at the end of the LCA where it attaches to the frame/crossmember.
