Old 06-04-2019, 05:48 AM   #1
maytag
Who's askin'?
maytag's Avatar
Originally Posted by Jeeab View Post
When the temp got to max, my oil light turned on and I had a knocking sound come somewhere under my feet. Side note is that the heater was not blowing hot air even though the car was cooking itself.
What is also unknown to me are those loud clunks that started happening when that oil light turned on.
So......
Not to be all negative Nelly here..... but;
I know you said it was only a block away, but either that's a very LONG block, or you were going very slow. You kept driving with the car overheating, long enough for the oil light to come on. And then it started making noises, you described them as "clunks", yet you kept driving it home.
I'm with JFP here: what may have been a simple low-on-coolant issue (that's why your heater was blowing cold) is almost certainly a much bigger issue now.
My fingers are crossed for ya.
First thing I'd do is dump the oil and inspect it and the filter. Might as well make sure the motor's still good before putting a new water pump on it.
