Old 05-31-2019, 02:05 PM   #20
JFP in PA
All the AOS operate the same way, they are a throttling device, not unlike the cooling system's thermostat, the take a relatively high vacuum level at the intake (well over 20 inches of mercury) and reduce it to a level (five inches of water) conducive to controlling the low tension rings pressure against the cylinder liners. Regardless of how high or low the intake vacuum level is, the AOS will hold that steady five inches of water in the sump. As a comparison, you cannot even see 5 inches of water on a vacuum gauge calibrated to inches of mercury. One inch of water is only 0.0734824 inches of mercury, so five inches of water is only 0.367 inches of mercury, not enough to even move the needle on a tool calibrated in inches or mercury, hence the need for manometer to read the lower vacuum levels accurately.
