Old 04-26-2019, 01:32 PM   #1
jdstro
R3v01u7i0n4ry
Alarm system/keyless unlocking issue
A little background info...about 2 years ago I purchased a 2000 986 boxster that was in nearly perfect condition. As luck would have it, a few months later it was broken into and suffered some damage to the center console and the unit under the driver's seat had to be replaced. Ever since then the key fob has not been working properly. When used the car unlocks then locks then the horn sounds twice. When trying to unlock it the exact same process occ and to unlock the car the door has to be manually unlocked. The dealership near at the time did some testing and deduced it was from the driver's side door lock mechanism. Since then both the driver's side and passengers side door lock mechanism have been replaced with no effect. Also as I mentioned there was damage to the center console, I bought a used replacement center console unit and replaced the whole thing. I've seen mention of the console lid sometimes causing problems. This issue has been slowly eating at me, any help on the matter would be greatly appreciated
jdstro is offline   Reply With Quote
