Old 04-16-2019, 08:46 AM   #22
tonythetiger
Will there be cake?
tonythetiger's Avatar
Originally Posted by Turbodad View Post
My problem turned out to be a weak "positive" ground in the engine compartment. It was rusty, and if I wiggled the cable and turned the key the engine would start. Disconnect the battery. It is located in a black plastic box next to the power steering reservoir. Use a screw driver to pop the box open and a 14 mm socket to remove and clean the nut.
thanks for the update! also glad it worked out for you.
