Old 03-08-2019, 07:38 AM   #1
JFP in PA
Originally Posted by PaulE View Post
I think LN refers to the IMS Solution as a Permanent Solution. Final Solution has a bad historical reference. What I find interesting is that RND is another Charles Navarro company and they offer the RND RS Cylindrical Roller IMS bearing retrofit, which is what the use in their RND rebuilt M96 and M97 engines. The IMS Solution has a journal bearing, just like the bearings used on the crankshaft and rod big ends in the rest of the engine, along with the front bearing in the IMS. Why Porsche ever thought using a grease filled sealed bearing (lubricated for life, ha ha) was a good idea, along with a 15,000 mile oil change interval by the way, will always be a mystery to me.
For my rebuild after a ceramic IMSB failure, I went with the IMS Solution. For me it is the final solution, because if the engine fails again I will be done with this car!
The two products are based on different technical premise's: The IMS Solution is based upon the long proven bearing design used in the air cooled turbo engines, the DOF is based upon the questionable premise that "it is not the bearing, it is the lack of lubrication". The reason this is questionable is that if it really was the lack of lubrication, the dual row bearing with twice the bearing surface contact area should fail more frequently than the single row, "due to a lack of lubrication", which is exactly counter to reality.....
