Old 03-02-2019, 07:38 AM   #20
JFP in PA
Thanks JFP it makes sense, I will buy a new oil cap for the 981 and make a new adapter.
Does the vacuum value (5" of water, or less) remains the same for the M97A1 engine as well? Thanks again!
Yes, they are pretty much the same. What you are looking for is the “steady state” (read fully warmed up engine) reading. Typically they run in the 4-5 inches of water range; anything above 6-7 is a failing AOS, and no vacuum or slight pressure is also a separate failure mode. This is why any serious “back yard” water cooled Porsche wrench should have one of these manometers, the test is a quick and deadly accurate diagnostic tool.
