Old 02-11-2019, 08:12 AM   #1
JFP in PA
Originally Posted by Anker View Post
AOS can't pressurize the crank case. It uses vacuum to lower the crank case pressure.
Correct, but if the AOS fails, blow by from the low tension piston rings will.
