Old 11-07-2018, 08:16 AM   #1
JFP in PA
Duly noted. Thank you very much.
I will be dropping the pan. New filter. New gasket.
How is the fluid removed from the TC? Does everybody just leave it in there?
What fluid would you recommend for the flush... as I will be concluding with the Pentosin 1 ATF.
Thank you.
We flush with the factory fluid. The only realistic way to clean out the converter is to fill, run, and dump the trans 3-4 times.
