Old 09-29-2018, 11:23 AM   #3
maytag
Who's askin'?
maytag's Avatar
Did you bench bleed the master cylinder BEFORE installation? If not and you weren't careful you have pushed air into the ABS pump and system. There is a procedure to do solve this I just don't have ATM. Off hand it will involve activating the ABS using a Durametric and bleeding.
+1, with everything Monty just said. And he's probably describing the same thing I skimmed. Makes sense it's the ABS, not the PSM. (Though related, haha)
