Old 09-19-2018, 03:43 PM   #1
JFP in PA
Originally Posted by speedyspaghetti View Post
He said the RMS is no problem, but also suggested the EPS RMS solution kit - does anyone have experience with this? Is it worth the cost over just replacing with an oem RMS?
Don't do it. This system requires machining the engine cases which is both risky and totally unnecessary, and locks you into using their seal only. The $20 factory PTFE seal will work just fine.
