Thread: Odb ii
Old 08-16-2018, 11:04 AM   #1
911monty
911monty's Avatar
Originally Posted by doridori View Post
Hi Lapister, thanks a lot for the advice. For the cold start, how cold of the temperature it needs to be to be really considered as a cold start?
Per the OBDII manual: "Warm up is characterized by two specific requirements. After the engine is started, the coolant temperature must reach 160-degrees Farenheit and the ECM must see an increase of 40-degree or more in coolant temperature. If the engine is started and is already at 130-degrees that would not constitute a warm-up to the ECM".
