Old 06-23-2018, 06:51 PM   #15
JFP in PA
Originally Posted by Rickvd View Post
I measured cam position 1 and 2 deviations with the Durametric, Cam 1 was steady at 3.22 cam 2 was reading -0.45 and steady. The car is a 2004 Boxster s, there are no engine alarm codes or cel, the car seems to be operating properly. My understanding is these two readings should be close(ER) together. I uninstalled the software re downloaded and reinstalled the software. When checked After this the observed values were the same. If it was a failed sensor I would have assumed there would be error codes or noticeable performance degrade. What have others observed? Thanks Rick
The deviation spec for the car is +/- 6 degrees.
