Old 06-19-2018, 05:29 AM   #2
78F350
Motorist & Coffee Drinker
78F350's Avatar
One last thing... The vacuum hose for the brake booster is connected on the right rear of the engine for Tiptronic and to the left front with the manual transmission. You should be able to move a cap (sealing the fitting) from one end to the other and connect up your existing vacuum hose.
Copy/paste from an old post:
On a manual transmission there is only an elbow fitting at the left front of the intake manifold (no. 23):
On the Tiptronic there is only a blank cover in that position. The Venturi tube connects to the right rear intake manifold and additionally to the pre-throttle intake, then terminates at the front left to connect to the booster line. The effect is greater vacuum.
and
