Old 05-30-2018, 07:29 PM   #1
Caeg
Where did you read that nonsense?
Yes, it affects both and that is likely your issue.
Look through your center vent with a flash light and you'll see the heater core flap. Cycle from cold to hot and watch it to ensure that it has a full range of movement. If it does, fix your missing flap foam.
http://986forum.com/forums/515251-post38.html
If that’s the issue that’s good to know. I looked through the vent and I don’t see any movement from the flap. I’m guessing that’s a separate issue I’m going to have to resolve?
Caeg is offline   Reply With Quote
