Old 04-23-2018, 09:23 AM   #1
911monty
911monty's Avatar
Originally Posted by Adrian Thompson View Post
Thanks. I replaced those plastic panels with new ones when I did it. See the screw attaching the cable to the bottom? When installed does the cable go straight up, or does it angle towards the outside of the car around the outside of a tab? That's how I have it, which I thought was the correct way, but now I'm thinking it should go straight up.
It routs exactly as shown, straight up. You can see the guide/support on the new piece I am holding just above the tab, Also see that spring/lever on the main bow? did you get that routed properly?
