Old 02-24-2018, 07:51 PM   #11
78F350
Motorist & Coffee Drinker
78F350's Avatar
Waiting for the title...
The car is running great, but I can't drive it anywhere yet. I had thought the Tag Agency was going to hold my title application until I returned to get the rebuilt title, but they went ahead and sent it in for an Oklahoma Salvage title. It usually takes about a week for the new title to arrive, but this one is taking longer.
I took care of a few minor issues, but I don't want to do anything major until after I put some miles on it. I replaced the secondary O2 sensors and air injection pump, cleaned and lubed the brake light switch, then installed the matched lock tumbler in the door. Everything was smooth and easy except the lock tumbler.
I had to remove the door latch assembly from the inside of the door to get the old lock tumbler out. It's a kind of tight fit for big hands. While trying to pull the lock mechanism out, I inadvertently held the lock lever to the unlock position, causing the windows to automatically go down (a special feature on the Boxsters). At first, I had no idea why the window was going down, but knew that I could shed a few fingers if the window pressed them against the sharp metal edge of the frame. I barely got my hand out in time and only lost a little skin.
***Safety Tip: The first step is always "Disconnect the battery."***
The car is back out of the garage and covered. I start a week of day shifts on Wednesday and really hope to get the title before then. I have plenty of slack time at work, but can't be more than a couple minutes away from my office. If I drive it to work, I can give it a good cleaning and drop it off at the tire shop across the street for a new pair of rear tires.
For now, we just sit and wait.
78F350 is online now   Reply With Quote
